configure pim shutdown-priority
configure pim {ipv4 | ipv6} [ {vlan} vlan_name | vlan all ] shutdown-priority number
Description
Configures the priority for out of memory shutdown.
Syntax Description
ipv4 Configures a PIM timer on IPv4 router interfaces.
ipv6 Configures a PIM timer on IPv6 router interfaces.
vlan_name Specifies a VLAN name.
all Specifies all VLANs.
number Priority for VLAN range is [0 - 65535].
Default
IPv4.
Usage Guidelines
None.
The following example configures the shutdown priority for VLAN 36:
config pim vlan v36 shutdown-priority 22
This command was first available in ExtremeXOS 12.4.
The ipv4 and ipv6 keywords were added giving an option to support this functionality in IPv6 as well in ExtremeXOS 15.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
